flex+1500++tx+bandwidth
William Schauff
Hi dear friends!
Please let me know if there is a possibility to improve Flex 1500 TX bandwidth up to 10/12Khz to send DRM .
TNx
William - py2gn
TNx
William - py2gn
Probably not, it was not designed to do that, I may be wrong. Who wants DRM anyway ? Occupies too much bandwith for HF
TNX anyway, John!0
Yes as you can drag the receive as wide as you like the Tx is taped at the widest filter.1
The conversion offset can be set for +9 KHz to -9 KHz. The TX bandwidth is fixed at 3.6 KHz. I am not aware of a way to expand it. The 5000 can go somewhat wider, and the 6000 series can go wider still.2
TNX Ken! I0
- 995 Maestro
