False Spectrum Signals
W5UN_Dave
W5UN_Dave Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
Take a look at these false signals on 40 meters on my SmartSDR/Flex 6700. Notice they are not present in the waterfall. What is causing this? Is this a problem?
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited May 2018
    That's weird - almost like they're displaying two different frequency ranges.  Does it show up anywhere besides 40m?  If you power-cycle does it return to normal?
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited November 2016
    What happened to your slice receiver. Isn't the white on red TX in the top right corner? All that screen shot shows is the white on red TX.
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    edited February 2019
    I haven't had time to see if this is repeatable. Walt, I only showed what was necessary.
  • W5XZ - dan
    W5XZ - dan Member ✭✭
    edited June 2019
    i had some strange sigs on the pan, too, dave.  a factory reset cleared it up for me.
    73, neighbor
    Does it do this all the time?  If so, please open a HelpDesk support ticket.  I agree with W5XZ that a factory reset may be in order.
  • Len
    Len Member
    edited July 2015
    I have this also
    Len WA7ZXZ
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    If they cannot be heard these non-audible artifacts wouldn't be "birdies" per say.
    Spurious as they are, it is unusual that they are present in one visual display and not the other.
    Code issue or rendering artifacts?
    Would seem likely they are to do the routines that do the averaging and sampling for just this display - curious if adjusting the FPS & other settings makes any difference?
    Interesting!
    Steve
    K9ZW
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    I haven't had the time to try duplicating this, but I do not see any at present. May have been a one time anomaly.
    edited December 2016
    Let us know if it is reoccurring by opening a HelpDesk support ticket so we can investigate this behavior..
