1.4.0 radio freeze audio / panafall 0 dropped packet
Marc Lalonde
Hi at fist V1.4 work good but since last 24 hour it radio freeze at random intervals
may freeze from 5 -15 second 2 to 3 time in a minute (same in TX !!! )
if do a cold reboot seem to fix for some time then restart
when freeze audio cut and panafall to ,but latency was < 1ms whit 0 dropped packet
and my audio come from back of the radio
any idea ?
Radio was flex 6500 / Win7 on a quad core I7 3.0Ghz
Marc L. VE2OLM
any idea ?
Marc L. VE2OLM
Are you receiving a disconnect popup message at any point?
Seems like Ethernet or CPU can be overloaded with third party with highest priority - updates, special backup etc, Marc check you network traffic and CPU usage simultaneously during this issue0
i think "but latency was < 1ms whit 0 dropped packet" is a trigger for message pop up0
Hi
if it was PC the Audio take from the jack on back of the radio will stay on
and no disconnect pop-up just freeze then restart
CPU on my PC still keep under 9%0 -
Overheat of the Video Card ? Temp is OK ? Active cooling i guess.0
Hi
pc work good i use it for my day work while i monitor on second screen VHF weak signal
and the system work 24/24 for last 6 Mont whit no issue
i downgrade to 1.3.8 no freeze yet0 -
Marc - did you load SmartSDR on any other PCs in your network?
I would also check to see if you have the latest video driver too.0 -
Hi TIM
for now Have SmartSDR only on 1 PC ,still not got issue since downgrade to 1.3.8
just check and it last video driver for intel 46000 -
I need to ask a few questions. Sorry if these have been answered before:
1.) is the PC connected using a wired Ethernet connection?
2.) when the audio freezes, are you using speakers connected directly to the radio?
3.) Does the panadapter freeze at the same time?
4.) After the freeze does the Network Monitor show any packet loss or high RTTs?
5.) How long does it take after a radio reboot for this to start happening?
I get this same behavior over wifi. My gig connected PC does not do this. However I can not find a reason for it over wifi. The network utilization is very low and PC cpu never gets over 15%. Mine freezes and stutters periodically. This is obviously a network issue in my case, hence my gig connected PC does not do this. But I would expect with the network utilization so low this would not happen with the new software.
My transmit audio is also very broken when on wifi. Its really unusable over wifi fo me. Tried it on several laptops all fairly high end.
When I get the stuttering/freezing, the PAN adapter and waterfall stutter also. No packet loss seen.
Not complaining, just throwing out my experiences also, so it may help diagnosis.
Regards,
William
1-) yes trough my gigabit router same as before
2-) speakers was connected to back of the radio (PWR-SPK jack label as 7 on documemtation) ,DAX also freeze on digital mode
3-) yes but Smart SDR GUI and PC still work
4-) no
5-) no more that a hour , sometime much less
still not have any freeze since downgrade back to 1.3.8
and 1.4 Have work for 2 day whit no issue before start freezing during local Net0 -
Thank you. And you are certain that SmartSDR is not loaded on any other PC on your network? This behavior is difficult to figure out if the PC is the only one any version of SmartSDR has been loaded on.0
William - your behavior over a wifi link is not unusual. Some wi-fi routers have more trouble streaming data than others regardless of the utilization. And the number of connected devices on the AP effects this too.
See the following article for more info: https://helpdesk.flexradio.com/hc/en-us/articles/203469425-Reasons-for-Wireless-Network-Performance-...0 -
Hmm, if it was working something must have changed somewhere.
See my post from yesterday.
Solved the deep freeze? DAX0 -
Generally speaking, I've had problems with about ever router I've owned (linksys, cisco, dlink) except for my current one which is an Asus RT-AC68U. It has been a very stable router with about 12+ devices always connected. There are newer models out now but I'm not sure how they compare.0
only thing that have changed was the mast mounted VHF pre-amp ,that extra gain may near overload DEMI L144-28 transverter input / but signal at XVRT input was fine
i also switch to HF and still have the freezing on ANT 1 and 2
putting back 1.4.0 now for see since 1.3.8 seem working
Tim yes only 1 pc running now on my LAN ,have shut down all other0 -
Yes I figured it was my wifi. That's why I ordered some cable and connectors to run hard lines. Just mentioned it.
Marc, Tim,
This is very similar to what I have seen and reported about 3 times before.. Everything from the radio pauses including speaker connected to the radio. PC network activity and CPU usage drop significantly. The DAX CP button changes from blue to yellow and then recovers when the audio does.. Actions in SSDR ( band/mode change ) initiated during a pause become effecting when the pause ends.
Marc,
for a test, next time it happens, reboot the PC ( not the radio ).
AL, K0VM
Hi ok still start ti freeze just after in transmit
image was better that word ;-)
http://youtu.be/HLymCeBrZyg0 -
Open up the DAX control panel and disable all channels and see if that helps.
Ok TIM you put finger on something
if if disable all my DAX seem to work
i also notice that if DAX running during freeze it tell no data from radio and icon turn orange
but how DAX may put off the radio and speaker out on the radio ?0 -
We are making progress. Another question.
1.) Does your computer have a Internet security program or fire wall running on it?
Hi yup NOD32 but that not changed and radio IP was DMZ
the AL, K0VM suggestion to reboot PC seem good for now
but still not figure how that may affect the radio ?
What I think is happening is that the network security suite is inspecting the streaming packets and that is slowing them down, SmartSDR v1.4 uses a different mechanism to determine if the radio and PC are disconnected and NOD32 is interfering with that.
Can you disable it and put the radio and the PC on the same network, not in an DMZ and see if that makes a difference.0 -
I had the same issue on the 6700. it happen only once a couple hours after my first install of SDR 1.4. The system recovered with out an issue. The radio keep the same frequency mode and band settings when it returned.
Steve, KD7IQL0 -
since reboot the PC it seem good
look like install program let some kind of residual of 1.3.8 running that radio not like ?0 -
OK. If it starts again, open a HelpDesk ticket and we will figure out what is happening.0
- 461 SmartSDR for Mac
- 113 Aurora
- 976 Genius Products
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
