Panadapter Display Settings.
Roger Cole
Roger Cole Member
edited March 2017 in FLEX-6000 Signature Series
When I get the display settings correct for RX the TX display is a completely black background with my information in a very dark blue.  If I change the settings on TX to what I want then the display on RX is unusable...very bright.  1.38 display remained same with RX and TX.  Thanks...Roger
    edited March 2017
    The signal strengths between TX and RX are so great in magnitude that the display rending is not going show the same color characteristics.  The waterfall "learns" the level of the noise floor and does an automatic back level adjustment based on the minimum power in an available FFT bin (an approximation of the noise floor).  If the waterfall was set to "learn" when transmitting when the minimum signal level is so much greater than on receive, when you transition back to RX, it would take several seconds for the waterfall to dynamically relearn the new minimum signal level and the waterfall would not be showing received signals in an optimal way.  So we turn off the waterfall black level learning while transmitting.  This is a consequence of the new waterfall code in SmartSDR v1.4.0.
  • Roger Cole
    Roger Cole Member
    edited March 2015
    When I use 1.38 the displays stay the same.  Thanks Tim.
