1.4 DAX & CAT with 1.3.8
Mark Erbaugh
I kept the install of 1.3.8 on my computer as per the recommendation, but it looks like the 1.4 installer updated DAX and CAT. if I want to run 1.3.8, is all I have to is let the radio upgrade it's firmware? Do I have to do anything with DAX or CAT?
You should't have to do anything with CAT and DAX, but if they give you problems, you can shut down the versions that are running and start the v1.3.8 versions manually.0
- 685 The Flea Market
