Where can I find the FreeDV installer?
Roy Laufer
Is the FreeDV installer for SSDR 1.4 available anywhere?
Roy, AC2GS
Roy, AC2GS
The FreeDV waveform was not included on SmartSDR v1.4.0. It will be in a subsequent release.2
Tim, Did it fall out in refactoring? The only reason I ask is that Gerald seemed to show working FreeDV in Oct 2014. Mostly just curious.
The radio destabilized with FreeDV running and we decided not to hold the release any longer to debug the issues.2
I just spent an hour looking for a way to make freedv work and finally found this thread.
The SSDR manual says:
Press the “Install” button, to bring up the Windows Explorer window for Waveforms. For this example, the name of the radio file is “FreeDV_Release.ssdr_waveform.” Double click on the entry with this name, or single click and press the “Open” button. “FreeDV_Release” should now be installed in the WaveformManager window Close the WaveformManager window.
I searched the internet for FreeDV_Release.ssdr_waveforms and found nothing.
Maybe reading manuals is not such a good idea every time...:*)
Tim - W4TME on 3/17/2015
"The radio destabilized with FreeDV running and we decided not to hold the release any longer to debug the issues."
So don't think your going to find it yet... View comment0 -
Tim, you may want to correct the web site... on the front page of the download is says under SmartrSDR version 1.4, however in the docs it specifically states it requires 1.5..
http://www.flexradio.com/amateur-products/flex-6000-signature-series/waveforms/
- 683 The Flea Market
