CW Skimmer and Parallels on a MAC
Bob G W1GLV
This is not an FRS problem. I can run CW Skimmer on a Win7 machine with no problems. I can also run it in BootCamp Win7 with no problems. Parallels in OS X 10.10 does not play well with CW Skimmer. I tried the same setup that is being used in Win7 machines. Here is the software I'm using. Windows 7, SDR-Bridge 1.1.0 and CW Skimmer 1.8. Here is screen shot of my results. Maybe some OSX guru can point me in the right direction.
Bob, defenetely you have a issue in Audio Device setup of the Skimmer. I am using MAC OS+ Parallels+Win10 Preview+Skimmer 1.8+Bridge 1.1.0 - no issues, all works fine. Usually i am starting Bridge behalf Administrator
BTW, trying to start Skimmer separately, without Bridge, in case negative expirience reinstall Skimmer0 -
Sergey, I would like to know what the message box in the lower right hand corner is trying to tell me. Like I said it works fine in the other Windows setups, I did not change any of the settings for Parallels.0
Bob i remember i have it at once a long time ago, issue is Skimmer trying to redirect audio stream into incompatible audio device: ex. very high bandwidth of audio I/Q (ex.: 192kHz) into the Parallels Audio Device. Trying to stop Skimmer decoding (not close at all), closing all unnecessary windows , and look into the Skimmer Audio Setup to solve manually. i guess it make sense
Just look into my Mac 5K with Parallels and Win10:
did screen short with my previous callsign: ra3ajk0 -
Bob,
There is a possibility that the problem can be solved by starting CW Skimmer outside of SDR-Bridge. To do that look in the SDR-Bridge/Shortcuts directory. These are handy because they start CW Skimmer the same way as it is done in Bridge, with the same INI files.
Start Skimmer with the shortcut. If things are working, you should see the waterfall correctly without starting Bridge.
Then start Bridge and check the Skim box if necessary.
73 ED W2RF
Guys, I figured out the problem. The problem lies with CW Skimmer. It tends to change the settings configured in the setup screen. I know that I setup DAX IQ 1 when I originally setup but on recheck it had changed to something else. Everything is working fine now. Thanks foryour help.0
Congrats Bob! Go to air!0
- 996 Maestro
