6300 only works on 6 meters with SSDR 1.21
Mike W9OJ
Clicked on 6 meters today on my 6300 and it went to 20 instead. I haven't been on 6 in a long time. I changed OS from Win7 to Win8.1 and no change. Upgraded SSDR from 1.3 to 1.38 and no change. Downgraded to 1.21 and 6 meters is back. Upgraded to 1.30 and 6 is gone again. It appears that the only way I can use 6 is if I run 1.21. Has anyone else had a similar problem?
You have a band persistence issue. You need to clear your persistence data with a reset to factory defaults. If you have saved any global or TX profiles, make sure you export those first.
FLEX-6300 Factory Reset:
Pressing and holding the power control button down for 5+ seconds when turning on the radio will trigger a factory reset. When the reset is triggered the power LED will begin flashing dim purple.0 -
Thanks Tim. That fixed that problem.
73 Mike W9OJ0
- 407 Community Topics
- 705 The Flea Market
- 205 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
