waterfall dissappeared
joel
I have the latest pwrsdr installed and has been working fine. I recently have lost the waterfall display and cannot seem to get it back? All other displays working ok. Any suggestions?
Export and then reset your database back to factory defaults. If the waterfall comes back, then the issue is your waterfall max/min gain settings in your previous database.0
have you tried a system database import under setup or even a factory reset ?
- 688 The Flea Market
- 105 Aurora
