Remoting Contacts FINALLY COUNT for DXCC - Sales Opportunity for V2.0 WAN
You are a man after my own heart. Short of chasing women in bars, what could be more fun than racking up a country per 807!
Jim
Since the XYL might be listening. Working DX from a bar is more fun than chasing women. BTW. Counterintuitively The Q rate increases exponentially with the number of 807's u imbibe1
There is no doubt that you are a man blessed with infallible logic!
It's hard to read exactly what they mean by all this, but it seems clear to me that if you are building your own remote station with (say) a Flex Signature Series radio, you are going to be just fine.
I expect some traditionalists to be upset for a while, but life moves on and amateur radio _is_ a technical undertaking. Truth is, the league is ahead of where I expected them to come out on this. Well done, ARRL!
But weren't we always told that WAN was a small niche market and to forget it!!
I'll bet that WAN becomes a substantial market for Flex that will differentiate it from all it's competitors.
It's been greatly overlooked just like the panadaptor feature was and now everyone wants it!
Lloyd
VE3ERQ1 -
It's pretty obvious that the 6000 series was designed for WAN. But they need to finish 1. 4 and 1.5 before they can devote resources to 2.0 WAN which will likely consume a lot of man hours to get right.1
I'd like to put my 2 cents (dos centavos?) on this idea of remoting Flex. First of all, the first thing that bothers me about the approach Flex is taking is the remoting of the power on and off. There is no "soft" on and off. A remote should have the stand-alone ability to do all functions including the on/off. For my Flex, I had to purchase an I/P remote relay system to I could remotely turn it on and off with my client computer. This would apply both on the LAN as well as the projected use with the WAN. Second, there is always the possibility the radio could lock on in transmit because the firmware, Internet link or computer failed. Again, one should have the ability remotely turn the power on and off. Again, I had to purchase a unit that would remotely remove the power to the power supply running the SDR. It even includes a telephone interface where I can turn the power on and off if the Internet should fail.
That is the reason I have been strong on using DNS services or some other device to continually monitor the I/P address from the ISP as to have a "complete" remote system all the above mentioned safeguards should be employed in a reliable remote system. From the indications I have inferred, no such safeguards or remoting the on/off has been discussed. Perhaps these issues are on the way or, at least, should be contemplated before selling the unit as remotable.
Jim, K6QE
I dunno,Jim. First of all, it's not entirely clear to me that the radio doesn't include the necessary hardware to support some sort of Wake On LAN or remote power on. We know it's not supported today, but has Flex told us if it has the capability?
Regardless, though, the radio is only one part of the equation in my book. You still have to build-out a well engineered remote station to be able to use the radio effectively. There are likely to be things other than just the radio at your remote (rotator control, amplifier, etc) that need power. Might just as well spend a few extra bucks (OK, an extra hundred plus bucks) and get a nice remote power switch with a web interface that allows you to control multiple power outlets and even monitor the current draw on each.
Just the way I see it,
Peter K1PGV0 -
Plus lighting protection...
Wake on LAN is not needed for the radio. There is an RCA plug in the back which, when enabled, boots the radio. As long as you have some other remote capability for turning the 12v power on and off, that's all you will ever need to remote the 6xxx series from a physical power control and boot up standpoint. If only my PC was set up so nicely.
There is a very nice gadget which lets me control 8 ac power plugs with an internet addressable device. It's pretty much enough to run the radio if you build a simple circuit to run a reed relay to toggle the RCA input. There is more, but it's now pretty much off the shelf.
I'm looking forward to that remote operation from the Moon. The DXCC ruling sounds like a good thing, for the most part. Until someone airdrops a remote rig in a box on a rare entity and runs it from home all day and night. Technically okay, but not quite the spirit, eh?
- 692 The Flea Market
