Method of using blue tooth headset via DaX
k3Tim
k3Tim Member ✭✭✭
edited December 2016 in SmartSDR for Windows
I checked the list and this questions appears to be asked but not answered.
"Can on rcv / xmt with a BT headset?"
Under SmSDR-1.38 it IS possible.  Assuming DaX1 channel 1:
Windows:  Control panel -> Sounds
 Receive :
  select  Recording tab -> DaX Audio Rx1 -> Properties -> Listen
      check listen to this device
  -and-
      Playback through this device - select your BT headset
 Transmit:
   Once more in Playback tab  -> select BT Audio Input Device
        Check listen to this device
   -and-
        Playback through this device - DaX Audio TX 1 (DAX TX Audio)
Carefully set levels for the BT mic them SmSDR levels for DaX TX and VOX.
Vox works.  In the P/CW submenu of SmSDR the DAX must be highlighted.
Tried this to a local rcvr and audio in/out seem fine.
Of course, with 1.4 coming out next week this is more a mental exercise.
_..--
 Tim
