Flex 6300 to ALS 600. Connect ALC or not.
Scott Homstead
Scott Homstead Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
I just hooked up my new 6300. I have an ALS 600 which I previously ran to a kenwood through an ARB-704. I am unable to key the amp using the ARB-704 however I am able to key the amp directly from the 6300 to the Amp. My question is when directly connecting the 6300 to the ALS600 should I also be using the RCA plug into the ALC on the amp and radio or is that not necessary?  Should I be using the ARB-704 or is that unnecessary as well?
  • RoyS
    RoyS Member ✭✭
    I use an ALS-600 with my 6300 and don't use the ALC. I also use the RCA TX out on the 6300 to switch the ALS-600 direct. I've had no problems but I use care not to overdrive the ALS-600. I try not to drive the amp over 500 watts peak.
    When I first got the ALS-600 about two years ago, I over drove the amp during tune up and wiped out the transistors. Expensive lesson learned.
    Good luck
    Roy - W5TKZ
  • Scott Homstead
    edited January 2015
    Thank you.  That is how I currently have it set up.  Understood on the overdrive.
  • Hugo Escalante
    Hugo Escalante Member ✭✭
    edited May 2016
    Roy, I'm serously looking at buying the Flex 6300 but I want to make sure I can run my ALS 600 amp. If I understand you right Iall I have to connect is the RCA TX OuT of the 6300 to the ALS 600?
  • RoyS
    RoyS Member ✭✭
    edited December 2016
    Hugo,
    That is correct.  I now have a 6500 but I still only use the TX Out to trigger the amp. I'm very careful when I tune up and so far have had no problems.
    Roy - W5TKZ
  • Don Stefanik
    Don Stefanik Member
    Running the 6300 and ALS 600. Driving it with 40 to 50 watts and no ALC or ARB704.
  • RoyS
    RoyS Member ✭✭
    Sounds good Don, have fun.
    Roy - W5TKZ
