2 METER PANADAPTER DISPLAY ON TRANSMIT
Drax
Drax Member
Is the panadapter on a 6700 supposed to display the 2 meter TX spectrum like it does when transmitting on HF?  Mine just freezes until the TX is unkeyed,
  • pa0bie
    pa0bie Member
    edited January 2015
    The panadaptor does not display the XVTR output.  That is the normal situation.
  • Joe - KC2TN
    Joe - KC2TN Member ✭✭
    edited March 2017
    Is this a permanent design? Or is it one of those "used to work" features in PSDR that will be put into SSDR when it catches up!
  • pa0bie
    pa0bie Member
    edited January 2015
    Since when do I give a " OFFICIAL RESPONE "  ?
    During transmit the panadator displays a signal what is taken off throug an attenuator from the FLEX-PA. That is internal hardware.  The intension was ( is ) to use this signal for pre distorsion the input signal to the PA to improve the IMD. Of course that would not work as soon as You place another PA behind Your Flex.
  • Joe - KC2TN
    edited March 2017
    Would there be no value or possibility to pick up a signal from the transverter port in transmit mode? Thanks for the Official response LOL,
  • pa0bie
    pa0bie Member
    edited January 2015
    As I said , that needs a hardware modification.  I do not expect that it would be easy or possible. Perhaps in the 7000 serie !
