MX-P50A interfacing
I've just purchased a MX-P50A amp to try get a little more "oomph" into my TX, but it comes with a cable for a Yaseu FT-817 for auto band switching (although manual switching can be done).  Do any of the more knowledgeable people know if i can modify this to do the same via the ACC socket on my 1500?
TIA
  • Jon_KF2E
    Jon_KF2E Member ✭✭✭
    edited July 2018
    Probably not. I don't believe the BCD data that Yaesu radios use to band change is available on the ACC port. You can probably do it with a parallel port on your computer and DDutil but I don't know the details.
    Jon...kf2e
  • Michael VE3WMB
    edited December 2014
    From what I recall the FT-817 outputs a voltage in the 0 to 5V range to convey band information. I am in a similar boat with my THP HL-45B amp as it is designed to auto band switch with an FT-817. I have been considering building a interface using an Arduino Nano to convert band info from PowerSDR into an analog voltage that mimics what would be provided by an FT-817 for the same band.
    I did find the following project, which is a similar idea but provides band info from PowerSDR to an Elecraft T1auto tuner.
    http://blog.zensunni.org/blog/2011/01/19/arduino-elecraft-t1-interface/
    This looks like it could be a good starting point. Notice that the author chose to set up the Arduino Nano (built-in USB interface) to listen for band info from DDUTIL rather than trying to build something that interfaced to the Flexwire port on the back of the 1500.
    I think I have all of the pieces, I just need to make some time and see if I can prototype something that will work.
    Cheers
    Michael VE3WMB
