Need help get N1MM+ to see the VSP"s to run CW.
Ron
I Need help get Flex 5000 and N1MM+ to see the VSP"s to run CW.
I keep getting error message
"Both interfaces radios have the same Radio NR. Each interface radio must have a unique Radio NR."
Even though I have separate numbers on both the Flex and N!MM+ This is the message I get from N1MMLOGGER.NET.
Any help would be greatly appreciated.
Ron,
I Think the message implies that you have N1MM set in a SO2 and that you have the same interface defined for both radios.. Set N1MM to SO1V mode and try again.. Just guessing here...
With SO1V you should have just one com port selected for CW in N1MM+..
AL, K0VM
Many Thanks to K9DUR I have got the CW working with N1MM+
73 de Ron N6XT
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
