Computer sound with Flex 3000
Bill -VA3WTB
Member ✭✭✭
I am wanting to use my sound card in my Flex computer to use as my audio EQ. How do I make the Flex see it?
You can use the program Audio Repeater included on all versions of VAC by Mutzychenko. Then use one DAX RX channel as Input for Audio Repeater and select as output your card or the Microsoft default device or EQ if it is a separated soft.0
Oh, sorry, I am afraid you are dealing with a Flex 3000 and then you don't have DAX included. Te solution is straightforward using a Virtual Cable Line 1 from Mutzyehncko¡s VAC as input to Audio Repeater instead of DAX and sending it to Audio Repater and then using your default sound device as output. ,
Luis EA3OG0
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
