TX Keying lines
Lewis Cheek
Lewis Cheek Member ✭✭
Looking for information on the TX keying lines with the Flex-6300, I see from manual RCA jack can sink 140 ma, I don't see specs for line on 9 pin connector.  I need to key my Elecraft KPA500 and switch two additional ( perhaps 3) devices. One device is the DX Engineering RTR-1A, the other is MFJ 1026 and perhaps the 20 VDC power supply used with Pixel Loop. Really love the folks around me with Plasma TV's :)
73's
Lew
N4CO
  • Anthony Bowyer
    Anthony Bowyer Member ✭✭
    edited July 2016
    From what I can gather, the 6300 only has one key line. If you need several, you may be able to isolate each one with a schottky diode (if what is keyed can handle the drop across them).
    If the keyed devices won't key that way, you might be way ahead to key a couple of optoisolators with SSR outputs.  An ASSR-1228 would do nicely. These have two 'switches' each and will switch near 60v at 200ma. Maybe a bit more if that are all DC.
  • Neil K2NF
    Neil K2NF Member ✭✭
    edited March 2015
    There are pin specs in the following document that can be downloaded from the Flex Web Site :
    FLEX-6000 SIGNATURE SERIES FLEX-6000 HARDWARE REFERENCE MANUAL
    Version 1.3
    8/15/2014
