How to hook up Tentec Centurion Linear to Flex 6300
Mark Erbaugh
Mark Erbaugh Member ✭✭
edited August 2016 in SmartSDR for Windows
Has anyone hooked up a Tentec Centurion Linear to a Flex 6300?  I was planning on using connecting pin 11 (Accessory Tx) of the accessory port to the Centurion's KEY IN and the Centurion's KEY OUT to pin 13 (Tx Req), but I just found a recent post that this keying loop doesn't work with CW in SSDR 1.3.8. QSK CW is the main reason for using a keying loop, so that the amp is not being hot switched.
Questions: Are the levels on the accessory pins 11 and 13 compatible with the KEY IN and KEY OUT jacks on the Centurion?
How can I keep from hot switching my amp when running CW with the Flex?
I saw a reference to DDUTIL in the other post about  Tx Req not working. Is DDUTIL a possibility?
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited September 2015
    Look in the menu of Ssdr under Radio Setup/transmit and if you experience hot switching just add some delay to either the ACC TX or RCA TX1 depending on how you interface the amp. I would just key the rig as usual and run an rca cable between the 6300's RCA output and the Centurion's key input. Don't worry about the "loop". That was designed for TenTec rigs. I used this same method with a Centurion and K3 combo with no hot switching evident. The Centurion is a wonderful QSK amplifier and has worked with several rigs I've had. Key it directly.
