Flex 3000 soft ware
Steve
flex 3000 i missed the update soft ware 2.5.3 and 2.6.4 i was at 2.4.4 and installed 2.7.2 did i miss any thing by jumping ahead .
Assuming the updated Firewire drivers were installed correctly and you can communicate with the 3000 I would think you would be fine. The installation info and instructions are in the release notes and detail anything necessary depending on which version you were upgrading from.0
Jon is correct. The newer versions of PowerSDR are all inclusive, so you did not miss anything.0
- 685 The Flea Market
