No Transmit with any Yaesu Mic
Flash Gordon
Flash Gordon Member
edited October 2019 in FLEX-6000 Signature Series
When mic is keyed, slice does not show any transmit. Just started after I entered another slice
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited October 2019
    Was your first slice indicating that the RED TX active?
    Some times when I open another slice to operate split and forget to reset my A slice to TX and turn the radio off: The next time I turn it on the radio TX does not appear.  Why you may ask ... because I left it on the B slice to transmit etc...
    Hope this helps...
  • DrTeeth
    DrTeeth Member ✭✭
    edited December 2018
    From the title, does it mean that any other make of mic is working and the issue is just with Yaesu ones?
  • James Kirk
    James Kirk Member
    edited November 2014
    Hi Flash, your rocket looked like a cardboard model with sparklers for engines.
    edited March 2017
    Is the slice designated as the transmit slice?  Also in the bottom right hand corner is a TX indicator that will show the state of TX and the TX interlock state.  Does it say Ready below the TX or Not Selected?
  • Flash Gordon
    Flash Gordon Member
    edited July 2016
    Thanks for all the replies. The fix was a combination of a number of issues, due to unfamiliarization with the radio.  I should have been more precise with my question. All Yaesu wired mic's work well, I was looking for the one with the best audio. I have settled on the MD-200 A8X. Problem solved thanks to several of your replies.
