Moving Virtual Cable to new computer
John Stuart KM6QX
How do I install Virtual Cables when moving PowerSDR 2.7.2 to new Window 7 computer?
Did you lose the installer for VSPManager?0
You find your old email from the VAC author, the one he emailed you when you paid for it. The email gives you a link, you go to the link and install to your new PC. No passwords, users names or anything.
Andy k3UK0 -
@John - I presume you are referring to VAC (virtual audio cables). If so, then the first step is to install VAC on the new computer. As with all software, please be aware of the license agreement and do not violate any of the agreed upon conditions. Some packages will only let you install it on one machine.
Second, VAC stores the cable configurations in the Registry. If you are good at doing registry surgery, you can copy the reg entries from the existing machine and put them into the new machine after VAC has been installed. Or you can use the VAC Reg file that FlexRadio created and install it after VAC 4.12 or higher has been installed http://www.flexradio.com/downloads/vac413-reg/
BTW, I have been extensively testing VAC with my FLEX-5000 and it seems to be working well. Much better than 4.13 which I do NOT recommend.
- 995 Maestro
