remote operations with flex 5K
Marty Bluhm
I have been remoting my 5K utilizing Teamviewer 9 and RemAud. This combo has worked good; but recently upgraded the os to Win7 Pro 64bit and would like to take advantage of the Remote capabilites of the os.
I have ran into a problem that baffles me. I can connect to the 5K via the MS remote no problem but when I bring up RemAud , it drops the Remote. Likewise, just the reverse if I bring up RemAud first and have audio coming in and then connect the Remote , the audio goes away.
I am 99% sure that it has to do with the vac lines ; but dont know how to fix it.
Has anyone experienced this problem and how do I remedy it?
Marty
W8AKS
Marty
W8AKS
Marty,
How are you connecting to the remote Windows computer? I understand you are using Microsoft RDP and RemAud. Is this connection local (within your house) or through the Internet with a firewall/router inline? This combination should work either way. Give me some more details on your network connection. Perhaps you are trying to use that same IP port?
I use RDP myself, with great results, along with a application called Mumble http://wiki.mumble.info/wiki/Main_Page for audio which utilizes an Opus based codec that had great sound fidelity and is highly effecient in lower bandwidth situations.
Carmine W1EQX0
- 688 The Flea Market
- 105 Aurora
