FlexLib.NET Nickname Property Inconsistency.
K9DUR
There is an inconsistency in the value returned by the Nickname property between the API and RADIO objects.
In the Radio Setup for my 6700, I have Nickname set to "Ray" and Callsign set to "K9DUR".
If I access the API.RadioList(0).Nickname property, it returns "Ray". However, if I access the RADIO.Nickname property, it returns "Ray,_K9DUR".
Shouldn't these two properties return the same value?
73, Ray, K9DUR
I have entered this into the bug tracker for additional investigation.0
Ray,
We went off to try to duplicate this issue and we aren't seeing what you're seeing. The RadioList is a collection of Radio objects, so RadioList[0].Nickname and RADIO.Nickname (meaning the same object) should definitely match as they are literally the same field in the same object.
I suspect that this may be a result of having 2 versions of Discovery packets being sent out (for backwards compatibility). The older version of Discovery packets used a different method to figure out the nickname, however, the newer version should get the right answer and they are always sent back to back. So perhaps if you checked the value immediately after the first packet arrived (and before the second), you might see something like this.
If you need help setting up to test whether this is the case, please shoot me a direct mail and we'll get this figured out.0 -
Eric,
I am still consistently getting this result. Haven't gotten back to you earlier because I have been buried. This week, I am getting ready for the booth at the Fort Wayne Hamfest this weekend, as soon as I get back, my 6700 is heading to Austin for the PEN. I will get with you after I get my radio back.
73, Ray, K9DUR
We addressed a similar issue recently with the Nickname that may address yours as well. Keep us posted.
- 692 The Flea Market
