Memories/User Markers on pan adapter
To satisfy the desire for Memories and Band Markers I suggest that A vertical line on the pan like the one to mark the center frequency of the receiver. The user can create one and there is a unique name and color given to each one by the user and there is a small block of text for a description that would appear when the mouse is over it. The user could also select the color of the line & name. The list of Markers could be brought up also from a menu for QSY and imported/exported as an CSV file. the list would be in order of assigned frequency. No memory number would be necessary. When the list of markers is exported, the user can manipulate,share and save them as desired. The record would be Frequency/name/color/description. If the list is imported, the user can choose between overwrite, merge, or replace for the list that is currently in the SDR. The user can also delete by name wildcard and/or color. The unique names should be limited to about 12 characters to keep from cluttering the screen and to also allow special lists to be manipulated such as for contesting.
colors and a couple of characters in the process can do a great job across the board to group frequency ranges and mark zones/edges/limits
Future of this idea?...might even see a automated marker pop up from a dx cluster software??? or even the other way.....you se a marker to a certain color and it automatically goes to the cluster from your cat?
Lets see some likes on this one! 73 N5PSM
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
