raw_iq_enable
kr4k
I see this in the transmit status. What does this mean, and what is the corresponding command syntax?
DAX audio provides a mechanism for transmitting real samples suitably unconverted for transmission. There is a not well documented feature that allows the transmission of IQ samples instead. This status indicates whether or not this mode is turned on.0
How do I turn this on? Currently, the status is '0'.
Also,
What is the streaming format into the radio?
Is it ethernet port only, or either ethernet or DAX?0
