Separate DAX and CAT executables
You can run each version of SmartSDR from it's own directory.
Look here: "C:Program FilesFlexRadio Systems"
You'll see the version number and inside each directories you'll see the DAX and SmartSDR CAT directories. Simply run the .exe file as required. Remember to close any running instances first.0 -
My bad, I should have said *installers* and not executables. I cannot edit the original post AFAICS.
I think it could be useful to be able to uninstall and reinstall DAX and CAT independently of SSDR, if possible.
