WWV and GEN with 1.38
Everytime I press the WWV band button, the radio goes to 14884.63 KHz. And sometimes when I press then press GEN, I get two open slices around the same frequency (148xx KHz) I have pressed WWV and moved the dial TO WWV, hoping it would stick, but to no avail. Never had this problem with 1.30. Am I the only one with this? And if so, what am I missing ?
Thanks, Walt
Have you check to see if the slice goes to W (wide).
I have notice that once in a while I click on the HRD cluster and the frequency jumps to another band way out 30 MHz plus. And the W (wide) indicator shows up.
I am keeping and eye on this, since it happened twice early today.
Mine just goes to 15, 000.000 on ssb or cw.
Rig is 6500.
Ned, K1NJ
The WWV "band" is 15.000 MHz +/- 10 kHz. If you select WWV (default=15 MHz) and change the frequency within the WWV band, then band persistence will remember that new frequency as the WWV band frequency.
You may have some lingering issues in the persistence database. I would export your global profiles, do a persistence database reset item 2 on page 6 of the SSDR v1.3.8 Release Notes) and then re-import your profiles. This may clear up the anomalies you are seeing.0 -
Thanks Tim - that seems to have cleaned it all up. You guys are such good help.
Walt
OT (but the title is spot on for this): What do WWV and GEN do? I assume from the above that WWV takes one to the US time signal station (nothing about it in the manual) but what about GEN?
Gen = general coverage WWW _=. WWV TIME SIGNAL0
Thanks Howard. That link you sent was for the current issue of RadCom - the monthly RSGB magazine. Would have got back to you earlier, but I was busy the past 25 hrs, hi hi.
Ok. Someone else posted the PDF I'm Finally back in California now Flights Took forever okay I knowI will upgrade to 1.3.8 and soon as I'm over bit of jetlag0
- 417 Community Topics
- 716 The Flea Market
- 224 SmartSDR+
- 471 SmartSDR for Mac
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 149 Contesting
