CAT KS command - no reaction
Sergey R5AU
KY CAT command work properly, but no reaction on the KS, CW speed via CAT can be setup from the CWX GUI only, have somebody the same behavior?
Hi Sergey,
I asked about that a while back. Other commands (e.g. speed, etc) are supported via the API but only the KY command is currently supported via CAT.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Hi Al, thank you, just tried to look into the search, but too many messages already, i think you know , KS documented in the CAT manual0
Hi Sergey,
The KS CAT command changes the internal keyer speed only.
Regards, Al / NN4ZZ
Got it, thank you, will look a way around.0
- 693 The Flea Market
