SteppIR Transceiver Interface 2
I have another question for WBB. I got my SteppIR working OK using your instructions. I also got my Yaesu rotorcard working. But I have some additional questions. I keep getting a "CAT server send error" even though the SteppIR and Yaesu are being controlled. And the SteppIR keeps switching over to "BI (3/4)" when I am tuning. Could these two be related? Also, how do you get the rotor to turn to a callsign location? It works OK when choosing a prefix or country from the menu? Can DDUtil access a callsign database? I am using Buckmaster's callsign database.
To answer your first question, once the topic's question has been answered it is closed for additional comments. This is to prevent a lot of additional "off topic" comments that may make finding the actual answer more difficult to extract from a post. If you need to ask a different question on any subject, search for it in the Community and then post a new topic (question) if you can't find the answer.
Since not all questions on this post have been answered, this topic is being left open for Community members to participate.
After some additional research, I believe I have my questions answered. From what I can see, DDUtil does not have the capability to work with a call sign database, correct?
Hello Richard,
I am not sure I have a solution for u on the rotator (Yaesu??). I use a Prosistel rotor with a Prosistel program integrated with dx monitor program to set rotor direction, etc (none of which interface with DDUtil or Flexradio). Here you might teach me what I need to do...
However, on the "SteppIR keeps switching over to "BI (3/4)" when I am tuning" issue; make sure you use a "null modem cable". I used a null modem "pin adapter" made in china, it worked sometimes and had errors other times. Errors went away when I used a null modem CABLE.
"Could these two be related"; I can not see how related. Not sure whey, however, I do have to "typically" load DDUTil program twice (for each new operating session) to get Cats lined up correctly)... this may be ur problem as well.
DDUTil is working correctly when u see the slice transmit frequency on both the DDUTil main window and in the SteppIRir window.
AK5WB
DDUtil cannot work with a callsign database but it can work with a third party program such as DX Labs suite or Ham Radio Deluxe which have DX Clusters and enable lookup of the callsign and providing interfacing to a rotor to turn to the correct azimuth. I do this with DDUtil and HRD Logbook/HRD Rotor control.
Dave, wo2x0 -
I do the same thing with DXLab.
Jon...kf2e
I use both HRD and DXlab with DDUTIL to control my Yaesu Rotor. DDUTIL is the "magic sauce" that ties everything together. The call sign database is accessed through HRD or DXlabs using an Internet XML feed from QRZ.com. I have been a DXLAB user for 10+ years and HRD for about 8 years. I swap between them depending on the mood I am in albeit lately I have been favoring HRD. BUT DDUTIL allows both to work at the same time. Rotor to call sign database operation is virtually seamless.0
I have a question I have Y-cable from SteppIR that is configured for my old Mark V Yaesu.
I would like to change the Pin out to Kenwood settings for the Flex 6500.
Would someone in the group have the pin out?
Hi Ron,
With SmartSDR/Flex 6000 you can use DDUtil to share CAT info with all your devices. You would need a free com port on the PC to connect to the SteppIR control box. The DDUtil WiKi has the exact wiring info (I do not have a SteppIR).
This eliminates the need of a Y cable.
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
