BSOD
Bob G   W1GLV
Bob G W1GLV Member ✭✭
BSOD when installing V1.3 with Parallels on my MAC mini. Itried 3 times with the same results. I have no clue on how to fix this since I'm new to Macs and Parallels. SSDR V 1.2.1 works great with Parallels.
    edited March 2017
    Looks like you upgraded from 1.2.1 and not the latest which was v1.2.17
    Uninstall 1.2.1 and 1.3.0, making sure to uninstall the DAX drivers with the 1.3.0 uninstall.  Uninstall CAT; both the old CAT and the FlexVSP driver using the Control Panel. (this is covered in the release notes.  Reboot and then install v1.3.0
  • Bob G   W1GLV
    Tim, problem was Win 7 was corrupted. Re-installed everything is good. From what I can see 1.3 is going to be a block buster. Fine job Flex.
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Hi Bob, i would to note what i have also BSOD on Parallels , the issue is - FlexControl, in case installing of the SSDr with unplugged FC you will have no problem. The issue not a FC itself  but result of the installation drivers of the FC during SSDR installation
