Flex Control out of control?
Randy Diddel
Hello,
5 days into the 6300, I am loving it. I can see there is a long way to go with SmartSDR but I am willing to wait that out. The RX is great and the filtering is amazing. Was playing around in the NA QP today with filtering and such. It will be a great contest/DX machine!
My problem: When I spin the Flex Control, sometimes it just keeps going, and going, and going..... Once I had to shut down SmartSDR to get it to stop. Anyone else have this issue? I did some searching but could not find an answer or solution.
Thanks and 73
K5RHD
/randy
Thanks and 73
K5RHD
/randy
I've got the same setup here Randy but never heard of that happening. Almost sounds like the control is bad but little do I know. Let know what you find out.0
It happens sometimes if your video card is not quite up the the task.
One helpful trick on Windows 7 & 8 is to go into Control Panel > Hardware and Sound > Devices and Printers, and look at the COM port that runs the FlexControl Knob.
Open its properties and find the tab that allows you to change the parameters that control the FIFO buffer. Turn them OFF or all the way down. That way the serial port won't store up tics of the knob when it overruns the speed of the displays ability to shift the panadapter.
You can also slow down the FPS of the Display tam on the left side of the panel in SmartSDR. I currently use AVG: (averaging) at about 30 and FPS of 15 and it still looks good. This reduces the load on the CPU and video card a bit and seems to help on my computer.
For more info, search for articles about "Flex Control Knob Overrun" and similar titles here on the Community.
Ken - NM9P
3 -
Thanks Ken, That really helped. I adjusted both- 15FPS on the display and FIFO buffer off. Works just how I would expect it to now.
Randy - K5RHD0 -
Just happened to me and followed the instructions and it's fine now thank you....
Ditto, and it works well while using FlexControl with DDUtil V3.
Paul, W9AC
This happens to me too when the slice receiver is at the right or left edge of the screen and the panadapter needs to scroll. I sorta got in the habit of just scrolling the panadapter with my mouse so that the slice receiver is in the middle of the screen before touching the flexcontrol. I'll try the trick mentioned above and see if it helps.1
Robbie, Thanks! I noticed that but did not pay much attention. i will try it out when I get home this evening.0
This has been an ongoing problem with SSDR. Many Flexers have complained about it. I personnaly have tried all the tricks but nothing seems to work.0
The Contour USB Shuttle Xpress is a nice alternative. Low profile, click detent. No skipping or skating.
