PowerSDR (partly) fails to remember Antenna settings
N7AIG
Not a biggie, but I am using a Pixel Tech mag loop antenna that I dare never pump any TX power into from my Flex-1500. So I have that RX-only antenna plugged into the XVRX socket. I tell the Antenna dialog about this, along with Transmit set to XVTX/COM and be sure to have Lock checked.
On next power up of PowerSDR (v2.7.2) the RX is dead. Checking Antenna dialog, I see that both Receive and Transmit are set to XVTX/COM. Manually changing Receive back to XVRX makes the receiver work once again.
[PS: I looked all around the Flex website for a bug reporting channel and couldn't find one. Is this the proper place for submitting bug reports?]
- 73 de Dave, N7AIG
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
