New Version 1.2.17 Corrupted?
2»
  • K6OZY
    K6OZY Member ✭✭✭
    edited February 2017
    MD5 (SmartSDR_v1.2.17_Installer.exe) = c7ab32a688ea785bb407b5c88c74c418
    If you still can't download it from this ISP,  I put it on my server stack.   This will not be hosted permanently.
    http://www.k6ozy.us/stuff/SmartSDR_v1.2.17_Installer.exe
    This will rule out if it is their ISP, which I am not expecting is an issue.   This is the same file I used to install successfully on my 6700 & 6300 radios.
  • Ed_NZ1Q
    Ed_NZ1Q Member ✭✭
    edited March 2017
    Thanks Tim - and team. You guys are great!  And on a holiday non the less.
  • Tom
    Tom Member ✭✭
    edited July 2014
    Tim -- I'm convinced that the problem was that the Flex server was overloaded with too many download requests. I kept getting files in the 15-20 GB size range and all of them reported corrupt because they were incomplete. I was also seeing downlink rates ~300 Mb/sec on my 50+ Gb/s fiber connection.
    By Thursday AM I got the 44+ GB file first try and it worked fine. The download speed was running ~1 Mb/s.
    73, Tom K3IO
    edited December 2016
    It was not a bandwidth issue.  it was a CPU resource contention issue where the HTTP sessions were being dropped.
  • Jerry W2TXB
    Jerry W2TXB Member ✭✭
    Tried downloading on the main (radio room) PC and got the corrupted file message. Downloaded it on the "antique" (>6 years old) ThinkPad T61 (also via WiFi) and it worked, then tried again on the main PC and it worked. Also using TimeWiener RR as ISP.
  • Jerry W2TXB
    For some odd reason, Safari (aka, that "dead browser" ;) ) works when all others falter. Had the same thing when downloading upgrades from Chrysler. I am keeping Safari around, if just for that.
