Noise floor issues again
Greg
Greg Member ✭✭
edited March 2017 in SmartSDR for Windows
Started having the noise floor issues again today.  On 20M with preamp off my NF is usually around -110 to -115 dB.  I was on 6M on one slice/antenna and opened a slice/panadapter for 20M on the other antenna and the NF was about -82 dB.
  • Greg
    Greg Member ✭✭
    edited June 2014
    BTW the same process fixes it....shut down, remove power...then reverse the process and all is well again.
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
