What are the command response codes for the network API?
Steve Conklin
Steve Conklin Member ✭✭
edited February 2017 in SmartSDR API
Commands issued to the radio using the TCP/IP API return a hex value representing a 32 bit value.
This is documented on the wiki as follows:
"<hex response> = ASCII hexadecimal number (32-bit) return value (see table below for possibilities)"
but there is no table.
From another post in this forum, I found the following:
"A 0x1xxxxxxx message is styled as Informational.  A 0x5xxxxxxx is an error."
And from observation, zero is success.
Is there any more information available than this?
Thanks.
  • Steve-N5AC
    Steve-N5AC Community Manager admin
    Yes, the original intent was to post all of these in the wiki along with the command they could be issued for.  The wiki has aged a lot though and so there's not a lot of info in there that we'd like to get added.  Here's a definitive list as of today - not with a lot of descriptions.  The ones that have an SL_R also have a text description further down in the list
    ///*! file messages.h
    // * Copyright 2012-2013 FlexRadio Systems.  All Rights Reserved.
    // *  Unauthorized use, duplication or distribution of this software is
    // *  strictly prohibited by law.
    // * author Stephen Hicks, N5AC
    // *  DATE:   04-SEP-2012
    #ifndef SL_MESSAGES_H
    #define SL_MESSAGES_H
    #define SL_ERROR_BASE 0x50000000
    #define SL_INFO     0x10000000
    #define SL_WARNING 0x31000000
    #define SL_ERROR 0xE2000000
    #define SL_FATAL 0xF3000000
    #define SL_MYSQL 0x00001000
    #define SL_NO_FOUNDATION_RCVR SL_ERROR_BASE + 0x001
    extern char*SL_R_NO_FOUNDATION_RCVR;
    #define SL_LICENSE_NO_SLICE_AVAIL SL_ERROR_BASE + 0x002
    #define SL_ERROR_ALL_SLICES_IN_USE SL_ERROR_BASE + 0x003
    #define SL_ERROR_SLICE_PARAM SL_ERROR_BASE + 0x004
    extern char* SL_R_ERROR_SLICE_PARAM;
    #define SL_MALLOC_FAIL_SIGNAL_CHAIN SL_ERROR_BASE + 0x005
    #define SL_MALLOC_FAIL_DSP_PROCESS SL_ERROR_BASE + 0x006
    #define SL_NO_SCU_AVAILABLE SL_ERROR_BASE + 0x007
    #define SL_SCU_NOT_IN_USE SL_ERROR_BASE + 0x008
    #define SL_NO_FOUNDATION_RX_AVAILABLE SL_ERROR_BASE + 0x009
    #define SL_FOUNDATION_RX_NOT_IN_USE  SL_ERROR_BASE + 0x00A
    #define SL_OUT_OF_MEMORY SL_ERROR_BASE + 0x00B
    #define SL_FREQUENCY_OUT_OF_RANGE SL_ERROR_BASE + 0x00C
    extern char* SL_R_FREQUENCY_OUT_OF_RANGE;
    #define SL_INVALID_SLICE_RECEIVER SL_ERROR_BASE + 0x00D
    extern char* SL_R_INVALID_SLICE_RECEIVER;
    #define SL_INVALID_FOUNDATION_RX SL_ERROR_BASE + 0x00E
    #define SL_INVALID_DSP_PROCESS SL_ERROR_BASE + 0x00F
    #define SL_INVALID_SIGNAL_CHAIN SL_ERROR_BASE + 0x010
    #define SL_FREQUENCY_TOO_HIGH SL_ERROR_BASE + 0x011
    #define SL_NYQUIST_MISMATCH SL_ERROR_BASE + 0x012
    #define SL_BAD_COMMAND SL_ERROR_BASE + 0x013
    extern char* SL_R_BAD_COMMAND;
    #define SL_UNKNOWN_COMMAND SL_ERROR_BASE + 0x015
    extern char* SL_R_UNKNOWN_COMMAND;
    #define SL_MALFORMED_COMMAND SL_ERROR_BASE + 0x016
    extern char* SL_R_MALFORMED_COMMAND;
    #define SL_NO_SUB SL_ERROR_BASE + 0x017
    extern char* SL_R_NO_SUB;
    #define SL_BAD_SCU_NUMBER SL_ERROR_BASE + 0x018
    extern char* SL_R_BAD_SCU_NUMBER;
    #define SL_UNKNOWN_PREAMP SL_ERROR_BASE + 0x019
    extern char* SL_R_UNKNOWN_PREAMP;
    #define SL_NULL_POINTER_IN_SIG_CHAIN SL_ERROR_BASE + 0x01A
    extern char* SL_R_NULL_POINTER_IN_SIG_CHAIN;
    #define SL_REF_COUNT_UNDERFLOW SL_ERROR_BASE + 0x01B
    extern char* SL_R_REF_COUNT_UNDERFLOW;
    #define SL_INVALID_MINIMIXER_RX SL_ERROR_BASE + 0x01C
    extern char* SL_R_INVALID_MINIMIXER_RX;
    #define SL_NO_MINIMIXER SL_ERROR_BASE + 0x01D
    extern char* SL_R_NO_MINIMIXER;
    #define SL_SHARED_MINIMIXER SL_ERROR_BASE + 0x01E
    extern char* SL_R_SHARED_MINIMIXER;
    #define SL_NO_MINIMIXER_IN_RANGE SL_ERROR_BASE + 0x01F
    extern char* SL_R_NO_MINIMIXER_IN_RANGE;
    #define SL_MMX_LIMIT_REACHED SL_ERROR_BASE + 0x020
    #define SL_SECURITY_FAULT SL_ERROR_BASE + 0x021
    extern char* SL_R_SECURITY_FAULT;
    #define SL_RECAHED_MMX_LIMIT SL_ERROR_BASE + 0x022
    #define SL_FOUNDATION_MMX_LIMIT SL_ERROR_BASE + 0x023
    extern char* SL_R_FOUNDATION_MMX_LIMIT;
    #define SL_AUDIO_CLIENT_NOT_FOUND SL_ERROR_BASE+0x024
    extern char* SL_R_AUDIO_CLIENT_NOT_FOUND;
    #define SL_AUDIO_CLIENT_STREAM_ID_NOT_FOUND SL_ERROR_BASE+0x025
    extern char* SL_R_AUDIO_CLIENT_STREAM_ID_NOT_FOUND;
    #define SL_AUDIO_CLIENT_GAIN_INVALID SL_ERROR_BASE+0x026
    extern char* SL_R_AUDIO_CLIENT_GAIN_INVALID;
    #define SL_AUDIO_CLIENT_PAN_INVALID SL_ERROR_BASE+0x027
    extern char* SL_R_AUDIO_CLIENT_PAN_INVALID;
    #define SL_SLICE_RECEIVER_NOT_IN_USE SL_ERROR_BASE + 0x028
    extern char* SL_R_SLICE_RECEIVER_NOT_IN_USE;
    #define SL_CLIENT_STREAM_ID_NOT_FOUND SL_ERROR_BASE + 0x029
    extern char* SL_R_CLIENT_STREAM_ID_NOT_FOUND;
    #define SL_UNKNOWN_ANT_PORT SL_ERROR_BASE + 0x02A
    extern char* SL_R_UNKNOWN_ANT_PORT;
    #define SL_INVALID_NUMERIC_VALUE SL_ERROR_BASE + 0x02B
    extern char* SL_R_INVALID_NUMERIC_VALUE;
    #define SL_INCORRECT_NUM_PARAMS SL_ERROR_BASE + 0x02C
    extern char* SL_R_INCORRECT_NUM_PARAMS;
    #define SL_BAD_FIELD SL_ERROR_BASE + 0x02D
    extern char* SL_R_BAD_FIELD;
    #define SL_NO_SUBSCRIPTION SL_ERROR_BASE + 0x02E
    extern char* SL_R_UNIMPLEMENTED_MODE;
    #define SL_UNIMPLEMENTED_MODE SL_ERROR_BASE + 0x02F
    #define SL_SIGNAL_CHAIN_ERROR SL_ERROR_BASE + 0x030
    #define SL_RFGAIN_OUT_OF_RANGE SL_ERROR_BASE + 0x031
    extern char* SL_R_RFGAIN_OUT_OF_RANGE;
    #define SL_BAD_MODE SL_ERROR_BASE + 0x032
    extern char* SL_R_BAD_MODE;
    #define SL_PARAM_OUT_OF_RANGE SL_ERROR_BASE + 0x033
    extern char* SL_R_PARAM_OUT_OF_RANGE;
    #define SL_BAD_METER SL_ERROR_BASE + 0x034
    extern char* SL_R_BAD_METER;
    #define SL_LOW_LEVEL SL_ERROR_BASE + 0x035
    extern char* SL_R_LOW_LEVEL;
    #define SL_INVALID_METER SL_ERROR_BASE + 0x036
    #define SL_TERMINATE SL_ERROR_BASE + 0x037
    #define SL_NO_COMMAND SL_ERROR_BASE + 0x038
    #define SL_FFT_FPS_OUT_OF_RANGE SL_ERROR_BASE + 0x039
    extern char* SL_R_FFT_FPS_OUT_OF_RANGE;
    #define SL_CLOSE_CLIENT SL_ERROR_BASE + 0x03A
    #define SL_TXSC_INVALID_TONE_INDEX SL_ERROR_BASE + 0x03B
    #define SL_INVALID_TX_ANTENNA SL_ERROR_BASE + 0x03C
    extern char* SL_R_INVALID_TX_ANTENNA;
    #define SL_TX_NOT_SUPPORTED SL_ERROR_BASE + 0x03D
    extern char* SL_R_TX_NOT_SUPPORTED;
    #define SL_BAD_ADC_SOURCE SL_ERROR_BASE + 0x03E
    #define SL_BAD_CAL_TABLE_TYPE SL_ERROR_BASE + 0x03F
    #define SL_BAD_CAL_TABLE_POINTS SL_ERROR_BASE + 0x040
    #define SL_CAL_TABLE_READ_FAIL SL_ERROR_BASE + 0x041
    extern char* SL_R_TRANSMIT_NOT_READY;
    #define SL_NOT_READY_TO_TRANSMIT SL_ERROR_BASE + 0x042
    extern char* SL_R_NO_TRANSMITTER;
    #define SL_NO_TRANSMITTER SL_ERROR_BASE + 0x043
    #define SL_INVALID_TUNE_POWER SL_ERROR_BASE + 0x044
    #define SL_UNCALIBRATED_POWER SL_ERROR_BASE + 0x045
    #define SL_BITE2_FAULT SL_ERROR_BASE + 0x046
    #define SL_CALIBRATION_WRITE_FAIL SL_ERROR_BASE + 0x047
    #define SL_INVALID_RF_POWER SL_ERROR_BASE + 0x048
    #define SL_READ_EMPTY_CAL_TABLE SL_ERROR_BASE + 0x049
    #define SL_INVALID_ADL5201_DEVICE SL_ERROR_BASE + 0x04A
    #define SL_INVALID_MIC_LEVEL SL_ERROR_BASE + 0x04B
    #define SL_INVALID_ALSA_CONTROL_NAME SL_ERROR_BASE + 0x04C
    #define SL_INVALID_OSC_INDEX   SL_ERROR_BASE + 0x04D
    #define SL_INVALID_BOOLEAN SL_ERROR_BASE + 0x04E
    #define SL_INVALID_BIAS_CAL_TARGET SL_ERROR_BASE + 0x04F
    #define SL_INVALID_PA_CLASS SL_ERROR_BASE + 0x050
    #define SL_MCL_INIT_FAILURE SL_ERROR_BASE + 0x051
    #define SL_UNEXPECTED_FILE_SIZE SL_ERROR_BASE + 0x052
    #define SL_FILE_SERVER_BUSY SL_ERROR_BASE + 0x053
    #define SL_INVALID_TX_EQ_STAGE SL_ERROR_BASE + 0x054
    #define SL_INVALID_RX_EQ_STAGE SL_ERROR_BASE + 0x055
    #define SL_INVALID_FILTER SL_ERROR_BASE + 0x056
    #define SL_STORAGE_NOT_INITIALIZED SL_ERROR_BASE + 0x057
    extern char* SL_R_INVALID_FILTER;
    #define SL_PTT_TIMEOUT SL_ERROR_BASE + 0x058
    extern char* SL_PTT_TIMEOUT_FMT;
    #define SL_INVALID_STREAM_ID SL_ERROR_BASE + 0x059
    extern char* SL_R_INVALID_STREAM_ID;
    #define SL_NO_CHANGE_ANT_IN_TX SL_ERROR_BASE + 0x060
    extern char* SL_R_NO_CHANGE_ANT_IN_TX;
    #define SL_INVALID_DSP_ALG_FOR_MODE SL_ERROR_BASE + 0x061
    #define SL_INVALID_CLIENT SL_ERROR_BASE + 0x062
    #define SL_INVALID_FREQUENCY SL_ERROR_BASE + 0x063
    #define SL_NO_IP_OR_PORT SL_ERROR_BASE + 0x064
    #define SL_INVALID_DAX_CHANNEL SL_ERROR_BASE + 0x065
    extern char* SL_R_NO_IP_OR_PORT;
    #define SL_NO_DAX_TX SL_ERROR_BASE + 0x066
    extern char* SL_R_NO_DAX_TX;
    #define SL_INVALID_DAX_IQ_CHANNEL SL_ERROR_BASE + 0x066
    #define SL_INVALID_DAX_IQ_RATE SL_ERROR_BASE + 0x067
    extern char* SL_R_INVALID_DAX_IQ_RATE;
    #define SL_SLICE_IS_LOCKED SL_ERROR_BASE + 0x068
    extern char* SL_R_SLICE_IS_LOCKED;
    #define SL_FREQUENCY_TOO_LOW SL_ERROR_BASE + 0x069
    #define SL_SO2R_NOT_VALID_FOR_MODEL SL_ERROR_BASE + 0x06A
    extern char* SL_R_SO2R_NOT_VALID_FOR_MODEL;
    #define SL_DUPLEX_NOT_VALID_FOR_MODEL SL_ERROR_BASE + 0x06B
    extern char* SL_R_DUPLEX_NOT_VALID_FOR_MODEL;
    #define SL_INVALID_BAND_FOR_PERSISTENCE SL_ERROR_BASE + 0x06C
    #define SL_LOOP_NOT_VALID_FOR_MODEL  SL_ERROR_BASE + 0x06D
    extern char* SL_R_LOOP_NOT_VALID_FOR_MODEL;
    extern char* SL_R_OUT_OF_MEMORY;
    #define SLM_INVALID_CLIENT_NOT_PAN SL_ERROR_BASE + 0x06E
    #define SL_NO_VALID_CLIENT SL_ERROR_BASE + 0x06F
    extern char* SL_R_NO_VALID_CLIENT;
    #define SL_EXCESS_TX_COMPRESSION_FAIL SL_ERROR_BASE + 0x070
    #define SL_NO_RECORDED_DATA   SL_ERROR_BASE + 0x071
    #define SL_BAD_ECO_TABLE_TYPE            SL_ERROR_BASE + 0x072
    #define SL_EMPTY_ECO_TABLE               SL_ERROR_BASE + 0x073
    #define SL_FULL_ECO_TABLE                SL_ERROR_BASE + 0x074
    #define SL_BAD_ECO_NUMBER                SL_ERROR_BASE + 0x075
    extern char* SL_R_BAD_ECO_NUMBER;
    #define SL_ECO_NOT_FOUND                 SL_ERROR_BASE + 0x076
    extern char* SL_R_ECO_NOT_FOUND;
    #define SL_MYSQL_CONNECTION_FAIL SL_ERROR_BASE + SL_MYSQL + 0x001
    #define SL_MYSQL_LOGIN_FAIL SL_ERROR_BASE + SL_MYSQL + 0x002
    #define SL_MYSQL_NOT_CONNECTED SL_ERROR_BASE + SL_MYSQL + 0x003
    #define SL_MYSQL_PCB_ALREADY_REG SL_ERROR_BASE + SL_MYSQL + 0x004
    #define SL_MYSQL_PCB_NOT_REGISTERED SL_ERROR_BASE + SL_MYSQL + 0x005
    #define SL_MYSQL_PCB_SN_BLANK SL_ERROR_BASE + SL_MYSQL + 0x006
    #define SL_MYSQL_PCB_SN_TOO_LONG SL_ERROR_BASE + SL_MYSQL + 0x007
    #define SL_MYSQL_MNEMONIC_BLANK SL_ERROR_BASE + SL_MYSQL + 0x008
    #define SL_MYSQL_MNEMONIC_TOO_LONG SL_ERROR_BASE + SL_MYSQL + 0x009
    #define SL_MYSQL_PCB_REV_BLANK SL_ERROR_BASE + SL_MYSQL + 0x00A
    #define SL_MYSQL_PCB_REV_TOO_LONG SL_ERROR_BASE + SL_MYSQL + 0x00B
    #define SL_MYSQL_PCB_MODEL_BLANK SL_ERROR_BASE + SL_MYSQL + 0x00C
    #define SL_MYSQL_PCB_MODEL_TOO_LONG SL_ERROR_BASE + SL_MYSQL + 0x00D
    #define SL_MYSQL_BAD_TESTID SL_ERROR_BASE + SL_MYSQL + 0x00E
    #define SL_MYSQL_PART_DESIG_BLANK SL_ERROR_BASE + SL_MYSQL + 0x00F
    #define SL_MYSQL_SW_NAME_BLANK SL_ERROR_BASE + SL_MYSQL + 0x010
    #define SL_MYSQL_SW_VERSION_BLANK SL_ERROR_BASE + SL_MYSQL + 0x011
    #define SL_MYSQL_BOM_REV_BLANK SL_ERROR_BASE + SL_MYSQL + 0x012
    #define SL_MYSQL_BOM_REV_TOO_LONG SL_ERROR_BASE + SL_MYSQL + 0x013
    #define SL_MYSQL_BOM_BLANK SL_ERROR_BASE + SL_MYSQL + 0x014
    #define SL_MYSQL_BOM_TOO_LONG SL_ERROR_BASE + SL_MYSQL + 0x015
    #define SL_MYSQL_MODEL_BLANK SL_ERROR_BASE + SL_MYSQL + 0x016
    #define SL_MYSQL_MODEL_TOO_LONG SL_ERROR_BASE + SL_MYSQL + 0x017
    // This response is sent when SmartSDR does not generate a result itself, forcing a default
    // response.  This generally indicates that the command code has failed to close the response
    // loop on all command paths
    #define SL_RESP_UNKNOWN SL_ERROR_BASE + 0x00001000
    extern char* SL_R_RESP_UNKNOWN;
    #define SLM_I_CLIENT_CONNECTED SL_INFO + 0x0001
    #define SLM_I_UNKNOWN_CLIENT SL_INFO + 0x0002
    #define SLM_W_SERVICE SL_WARNING + 0x0001
    #define SLM_W_NO_TRANSMITTER SL_WARNING + 0x0002
    #define SLM_W_INTERLOCK SL_WARNING + 0x0003
    #define SLM_I_MAX_CLIENTS SL_FATAL + 0x0001
    ///*!  messages.c
    // *   Messages
    #include "messages.h"
    #define ENGLISH
    #ifdef ENGLISH
    char* SL_R_UNKNOWN_COMMAND = "Command Unknown";
    char* SL_R_BAD_COMMAND = "Command Format Fail";
    char* SL_R_RESP_UNKNOWN = "Command result unknown";
    char* SL_R_MALFORMED_COMMAND = "Malformed command";
    char* SL_R_NO_SUB = "Subscription not found";
    char* SL_R_BAD_SCU_NUMBER = "SCU %d does not exist";
    char* SL_R_UNKNOWN_PREAMP = "Preamp selection must be o=off, 1=preamp1, 2=preamp2, b=both";
    char* SL_R_NO_FOUNDATION_RCVR = "Unable to get foundation receiver assignment";
    char* SL_R_NULL_POINTER_IN_SIG_CHAIN = "Internal error -- NULL pointer in signal chain";
    char* SL_R_REF_COUNT_UNDERFLOW = "FDX reference count underflow";
    char* SL_R_NO_MINIMIXER = "Unable to get minimixer receiver assignment";
    char* SL_R_INVALID_MINIMIXER_RX = "Invalid minimixer number (%d)";
    char* SL_R_SHARED_MINIMIXER = "Can't tune shared minimixer outside range";
    char* SL_R_NO_MINIMIXER_IN_RANGE= "No minimixer found in the frequency range";
    char* SL_R_SECURITY_FAULT = "Security fault; command not executed";
    char* SL_R_FOUNDATION_MMX_LIMIT = "Foundation receiver cannot tune due to minimixer frequency";
    char* SL_R_FREQUENCY_OUT_OF_RANGE = "Frequency out of range";
    char* SL_R_INVALID_SLICE_RECEIVER = "Invalid slice receiver (%u)";
    char* SL_R_AUDIO_CLIENT_NOT_FOUND = "No Audio Client found for submitted Client ID (%08X)";
    char* SL_R_AUDIO_CLIENT_STREAM_ID_NOT_FOUND = "slice %u not found in Audio Client (%08X)";
    char* SL_R_AUDIO_CLIENT_GAIN_INVALID = "Gain value not within required [0.0,1.0] range (%.13g)";
    char* SL_R_AUDIO_CLIENT_PAN_INVALID = "Pan value not within required [0.0,1.0] range (%.13g)";
    char* SL_R_SLICE_RECEIVER_NOT_IN_USE = "Slice receiver (%u) not in use";
    char* SL_R_CLIENT_STREAM_ID_NOT_FOUND = "Client stream ID 0x%08X not found";
    char* SL_R_UNKNOWN_ANT_PORT = "Antenna port '%s' is unknown";
    char* SL_R_INVALID_NUMERIC_VALUE = "Parameter is not a valid numeric value '%s'";
    char* SL_R_INCORRECT_NUM_PARAMS = "Incorrect number of parameters (%u) for command";
    char* SL_R_BAD_FIELD = "Bad field '%s'";
    char* SL_R_UNIMPLEMENTED_MODE = "Unimplemented mode '%s'";
    char* SL_R_RFGAIN_OUT_OF_RANGE = "RF Gain out of range (%.5f)";
    char* SL_R_BAD_MODE = "Unrecognized mode 0x08X";
    char* SL_R_PARAM_OUT_OF_RANGE = "Parameter out of range";
    char* SL_R_BAD_METER = "Bad meter number (%u)";
    char* SL_R_LOW_LEVEL = "33[91mNOTE: This is a low level command that may alter the internal consistency of the radio33[m
    char* SL_R_FFT_FPS_OUT_OF_RANGE = "FFT framerate of %u fps is out of range
    char* SL_R_INVALID_TX_ANTENNA = "Antenna %s is not valid for transmit
    char* SL_R_TX_NOT_SUPPORTED = "This radio does not support transmit capability
    char* SL_R_NO_CHANGE_ANT_IN_TX = "The antenna may not be changed while transmitting
    char* SL_R_NO_IP_OR_PORT = "Either the IP or Port required for operation is missing";
    char* SL_R_NO_TRANSMITTER = "The transmit slice has not been selected
    char* SL_R_TRANSMIT_NOT_READY = "The transmitter is not ready
    char* SL_R_INVALID_FILTER = "Invalid filter configuration (low >= high)
    char* SL_R_INVALID_STREAM_ID = "Invalid Stream ID (0x%X)
    char* SL_R_NO_DAX_TX = "You must enable transmit in DAX before transmitting";
    char* SL_R_INVALID_DAX_IQ_RATE = "Invalid DAX IQ rate";
    char* SL_R_SLICE_IS_LOCKED = "Unable to tune a locked slice -- unlock first";
    char* SL_R_SO2R_NOT_VALID_FOR_MODEL = "SO2R is not valid for this radio model";
    char* SL_R_DUPLEX_NOT_VALID_FOR_MODEL = "Duplex is not valid for this radio model";
    char* SL_R_LOOP_NOT_VALID_FOR_MODEL = "The loop selected is not valid for this radio model";
    char* SL_R_OUT_OF_MEMORY = "Out of memory error";
    char* SL_R_NO_VALID_CLIENT = "33[91mcalled with no or invalid client";
    char* SL_R_BAD_ECO_NUMBER           = "33[91mthe ECO number supplied is invalid";
    char* SL_R_ECO_NOT_FOUND           = "33[91mthe ECO number supplied cannot be found";
    char* SLM_I_CLIENT_CONNECTED_FMT = "Client connected from IP %u.%u.%u.%u";
    char* SLM_I_MAX_CLIENTS_FMT = "The maximum number of connected clients has been reached";
    char* SLM_W_SERVICE_FMT = "Service mode enabled on remote device";
    char* SLM_W_NO_TRANSMITTER_FMT = "Transmit slice has not been selected";
    char* SLM_W_INTERLOCK_FMT = "Interlock is preventing transmission";
    char* SL_PTT_TIMEOUT_FMT = "The PTT timeout timer has elapsed.  Release PTT to reset.";
    char* SLM_F_INVALID_CLIENT_NOT_PAN = "33[91minvalid client; not a panadapter";
    char* SLM_F_INVALID_CLIENT_NOT_FALL = "33[91minvalid client; not a waterfall";
    char* SLM_F_INVALID_CLIENT_NOT_FFT = "33[91minvalid client; not an FFT display";
