Receiver Spurs
Paul Christensen, W9AC
Receiver spurs on 6700. Test conditions: no antenna, preamp not engaged. Only one panadapter open. I've ensured its not power supply related by swapping 12V supplies.
Image 1 shows a 40m spur that resemble switch-mode noise. The spurs come and go as Rx A and Rx B are selected/deselected. It also changes when going from 40m, switching to another band, then coming back to 40m.
The next image shows 2m. This shows spurs all across the band.
Anyone else seeing this? Again, no antenna connected, preamp not engaged. If not, I'll work it out through Flex C/S.
Paul, W9AC
Paul,
I do not see either of those on my 6500..
AL, K0VM
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
