I have orange light on power switch when dc is applied to 6300 or when i power off.. is this correct
Paul - GI4FZD
Paul - GI4FZD Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
I can't find any info on the function of power indicator switch or what the various colours mean,
also what is the cleanest way to shut down, is it just exit smartsdr and then power down the 6300, (this is where I also get orange light on power button.
I take it there is no on/off switch like in powersdr.
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    Paul,
    I think this is what you are looking for...
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
  • Paul - GI4FZD
    edited June 2014
    Hmm,so orange is transmitting low power on transverter port,
    I havnt enabled transverter port and how can it be transmitting on xverter port when it is powered down or when dc is applied without powering up the radio.
    Am I missing a setting somewhere regarding the transverter?
    Does orange also mean standby, it does go briefly red when i switch of the power supply.
    Should I perform a factory reset?
    cheers
    Paul
  • George KF2T
    George KF2T Member ✭✭✭
    Don't take my word as gospel, but I'm pretty sure dim orange while the unit is "off" means the crystal oven is on and keeping everything nice and stable. Power is applied, but the radio is not on-line.
  • Paul - GI4FZD
    edited June 2014
    Yes George, I thought maybe that was it, it just does not appear to be documented anywhere, although I might have missed it.
    edited March 2017
    The 6300 will never show an orange power LED when powered down as it does not have a GPSDO option.  this looks to be a defect.  I have added it to the developer's bug tracker for additional investigation.
  • K1ESE
    K1ESE Member ✭✭✭
    edited December 2017
    I found the button goes orange if you have "Remote ON" enabled and the radio shut off.
  • Paul - GI4FZD
    edited June 2014
    That's the answer, the remote was on in the setup panel. once that is switched off the 6300 shuts down correctly...something to add to the manual.
    cheers
    Paul
    GI4FZD
    edited December 2016
    Very interesting.  That looks like a different defect.  Thanks for the feedback.  I will enter that into our bug tracker.
  • Paul - GI4FZD
    edited June 2014
    Is This a bug or a feature, is it there to indicate the rig is on remote standby?
    The answer to that is TBD once software development has a chance to investigate.
