Does anyone like those white lines in the waterfall when transmitting?
Now we know that the white lines in the waterfall when transmitting are by design. However for me, it is enough to see that the waterfall is black when transmitting. I don't need those white lines; in fact I find them distracting.
I would like to see an option to remove them. Or at least make them a darker color.
Other opinions?
73 Ed W2RF
Other opinions?
73 Ed W2RF
2
Hi Ed!
I like them when running digital, hate them on CW. Ambivalent about them on phone.0 -
It's CW that I also have the most problem with. Creates so much clutter it interferes with the RX waterfall. Useless :-)
Transmit is Incredibly useful. Allows me to visually monitor my signal. As effective if not more so than the MON function.0
White line is clutter? Not really.0
I think you are referring to the ability to monitor the TX signal in the waterfall, not to turn it off and replace it with a white line.
Ed,
I don't find the lines to be a problem on CW but I wonder if it depends on how you setup for CW.
Are you using QSK?
Or if not, do you use a short breakin delay?
In either case, there could be a lot of lines. On the other hand with a long (for example 300+) breakin delay, its doesn't seem to be a problem. A line between transmissions......
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com.0 -
Al,
There wouldn't be a problem with semi-breakin as you use.
I use QSK so the waterfall is full of white lines.
Al,
Before I got my 6500 I couldn't STAND QSK! Even with my TS-850. The noise just drove me crazy! But now, with the 6500 and 100 & 50 Hz filters, and the quietness of the rig, i have grown to LOVE it.
Funny how a great rig can change your impressions! Now if it is too noisy, I just realize that I have the AGC-T set too high, or have forgotten to set AGC to "fast" I have noticed that if it is set to MED or SLOW that the noise has a sort of spongy, spring-reverb like effect. with AGC on fast, things a really nice.
The white lines and other traces on the panafall during transmission don't bother me. I just tell myself "that was when I was transmitting. End of story. They are really helpful when operating splits with the XIT on Digital operation so I can compare my transmitted frequencies to the traces of other competing stations.1 -
Ed,
I get it now, for QSK it might be nice to have the option of BLACK lines or NO LInes on XMIT.
Regards, Al / NN4ZZ
.0 -
And I've learned that the while lines are only a problem for QSK CW ops... like me!
I just enabled the "Show TX in Waterfall" option. No while lines and it's beautiful!0
Yes, but the TX CW in the waterfall is not clean. It shows multiple sidebands, and is so bright that is it perhaps more distracting to me than the white lines!
Can one operate CW without QSK? (joking comment) It really is well done in the 6000-series. Such a pleasure operating code.2
would be great just have an completely OFF option3
How about a user preference to eliminate the white line?0
In your Settings.....Under the Transmit tab, enable "Show TX in Waterfall.
That makes the white lines black.
Does turn off the white lines, but replaces them with transmit spectrum. A third option would be great.
73 Ed W2RF
What would this 3rd option look like?0
It would look like the white line option, but the line would be black or a color of your choice. The waterfall would still freeze during transmit.
Use the "Show TX in Waterfall" setting. It freezes the waterfall and shows all black. Hold down your key and you'll see. You surely don't want a flashing white screen.0
On my test (just done) if Show TX in Waterfall is DISABLED, I see white lines on a frozen waterfall. If it is ENABLED, I see transmit signals on a black waterfall, which is NOT frozen.
I give up.1
I think he wants an option like the TX in waterfall OFF, but with NO lines at all.
C'mon Howard, that Ed said he'd prefer no display on transmission, similar to what you can do on the waterfall, by virtue of being his opinion/suggestion, it is fact, not subject to "no, you're wrong"0
This is funny
.....NO line = black flashing on.....Absence of a line = black.
How can I state this to be understood?
Another colored line = some other color flashing on.
Ed, you did, however, turn a perfectly valid idea into a question which is, likely, why there is so much push back. Personally, I like the idea, an option to turn it off. What you could do is end this debate, open another idea that says, "I'd like an option to not show the tramitted signal in the spectrum display".0
On my suggestion that started this thread -- to have an option to turn off the white lines or at least change their color -- I just want to reiterate that the option is not currently available.
Some have suggested that when Show TX in Waterfall is ENABLED, this is what happens. But it isn't. In that case the white lines and frozen waterfall are replaced by a live scrolling waterfall that shows the TX waveform. Just as the feature name suggests.
73 Ed W2RF
Think I was only responding to comments that indicate the feature is already implemented, which it isn't.
No that won't answer it. "Not showing the transmitted signal" means showing all the stuff in between key downs. That's what you get when you choose "disable". Due to latency in the receiver it shows the "dirty spectrum" from the switching process.
One could add a "Spectrum Mute" feature which would freeze the entire screen for X number of milli seconds0 -
I believe the blanking algorithm when in DISABLE is not timing correctly. Note that correct timing is applied to slice audio. So the spurious "dirt" in the spectrum is probably a bug.
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
