HRD Logbook and DM780 and DDUTIL
No, you simply use minideluxe, of you want to keep it simple. You don't use the HRD front end then.
http://www.vhfwiki.com/minideluxe
Scott AC8DE
thanks Scott...will give that a try.
Don,
Depending on your situation you might want to consider DDutil. I use it with my 6500 and it allows my Quadra amp to follow my radio and sets it's drive level. It also displays data from my LP-100a and provides control of my SteppIR. So, depending on your operating requirements it might provide many more features than just a HRD server.
Jon...kf2e
If you are using HRD 6.2 you will need the latest version of either MiniDeluxe or DDUtil. Both have been updated to support HRD 6.2 to allow correct frequency/mode tracking.
You will need to initially set up HRD to talk to SmartSDR directly through SmartSDR CAT. Details are available here https://community.flexradio.com/flexradio/topics/smartsdr_ham_radio_deluxe_dm780_howto_setup_guide
Once HRD is set up you can then shut down HRD and install either DDUtil or MiniDeluxe. In the new version of DDUtil on the first tab in the setup there is a section for HRD. Select 6.2 if you have the newer version or 6.1 if you have the older version of HRD and check the enable box. Now you can launch DM780 and HRD Logbook without having to run the main HRD program. Frequency and mode updates between SmartSDR, DM780 and HRD Logbook is VERY fast!.
I am using Windoze 8.1 Pro, HRD 6.2, DDutil with a 6500, Amp, Tuner, and meter. DDutil integrates all of them together. Steve (author of DDutil) is very responsive to the users and keeps the code updated with fixes, and frequently introduces new features.
73, Dan KM6CQ
Jon, thanks for the information about interfacing the Quadra.
Would it be possible for you start another conversation and go into more detail about your solution with the Quadra -- settings in DDutil, interface cable, band data #1 or #2, (Homebrew or source for the cable), tuning procedure etc. You seem to be the pioneer but others may have done it also and could add additional information.
I'd love to get to the point where the Quadra operates with the 6300 as it does with my Yaesu radios
Regards, John NA6L
John,
I'll put something together for you. All of the information you need is in the DDutil wiki, but it isn't consolidated very well. I'll outline the steps I went through to get my Quadra playing with my Flex.
Jon...kf2e
Wonderful.
John NA6L
thanks to all who responded. i have the last free version of HRD and all i had to do was download the latest version of Minideluxe. i use COM11 for CAT and COM10 for PTT. i set Minideluxe for COM11, WSTJ-X for Ham Radio Deluxe (the last rig on the list) and i now have the frequency data coming up in HRD Logbook. will see what i can do with DM780 tomorrow. what a great resource this reflector is.
- 685 The Flea Market
