How do I to get auto band switching on a THP HL-1.5KFX amp when hooked to a Flex 6300?
Doug Seyler
This amp has inputs for Icom, Yaesu and Kenwood band control. It does not have an RF sensing mode to automatically set the band. Thanks, Doug WB5TKI
Doug,
Flex uses the Kenwood CAT command protocol. So if the HL-1.5K can follow Kenwood I would think that it could follow Flex but the 6300 does not output RS-232 directly. You may need to use DDUtil as a interface between Flex and the HL-1.5K but I do not know if anyone has done that.. Check with K5FR and the DDUtil reflector ( DDUtil@yahoogroups.com )
See also 'Related Conversations' on this community.
Al, K0VM
Thanks Al!0
- 684 The Flea Market
