SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Adjusting Audio for Cleaner QSK Sidetone Flex6000
Also, as I bring my audio into the computer there is also audio adjustments in the computer and on the front of the speakers.
The chain of volumes looks like this:
1. Sidetone
2. Slice Receiver
3. Master
4. Computer input / output / master
5. volume knob on speakers
I just route the audio from the Flex 6300 to the speakers, not the computer.0
I was bringing the audio through the computer for digital modes before DAX. I continue to bring the audio through the computer not for digital modes, but for the simplicity of having one knob to turn off all audio in the shack with one knob. Also I don't have to bother with locating a second set of speakers.0
Where is the RF gain?
All I see is on the ANT menu a setting that has either 0 or 20. (Pre-Amp??)
Also under audio on the slice I see a setting slider ,,,I guess it is AGC?
Thanks,
Lee
Next to the AGC menu in the RX window is the RF Gain as it is sometimes called. I guess technically it's something else. Its setting varies per band and conditions.0
According to the book...the RF gain is in the ANT menu pop-out...but mine only has 0 or 20 not variable.
Next to the AGC settings (off, fast, med, slow) is a variable setting ...I assume that is the AGC thresh hold??
Lee
Yea I guess you're right. My RF gain slider is stuck. I assume that is for the pre amp on the other models. Anyway....I try to keep that AGC slider backed down as far as possible. It helps with the QSK noise somewhat especially on nights like this. Wow the QRN is loud.0
Were supposed to have a pre-amp on the 6300 too...I think that is the 20 setting...
OK, FB on the AGC...the book does talk about the rf gain and that 0 - 20 control says RF Gain on it..
What gives??
No RF Gain?
Lee
No I'm sure the 6300 doesn't have a preamp there fore the slider is dead.0
Here is the 6300 spec from the site:
Receiver Specifications- Receiver Architecture: Direct Digital Sampling
- Spectral Capture Units: One (1)
- Maximum Slice Receivers: Two (2)
- Maximum High Resolution Spectrum Displays: Two (2)
- Maximum Panadapter Width: 7 MHz
- ADC Resolution: 16-bits
- ADC Sampling Rate: 122.88 Msps
- Wideband Frequency Coverage: 30 kHz – 54 MHz
- DAX IQ Channels / Bandwidth Per Channel: Two (2) @ 24 kHz – 96 kHz
- DAX Audio Channels: Two (2)
- Amateur Band Preselector Coverage: NA
- Preamplifiers / Attenuators: 0 to +20 dB
- Spurious and Image Rejection Ratio: 80 dB or better
- External Powered Speaker Output Impedance Level: 600 Ohm Stereo Unbalanced
- 419 Community Topics
- 718 The Flea Market
- 228 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
