APPCRASH
Jerry W2TXB
Jerry W2TXB Member ✭✭
edited March 2017 in SmartSDR for Windows
Got this error message and SSDR had to be shut down and restarted. Also powered down the radio (6700... took ~30seconds) and restarted it.
Any ideas and help are appreciated.
Problem signature:
Problem Event Name: APPCRASH
Application Name: SmartSDR.exe
Application Version: 1.2.1.49
Application Timestamp: 53611ffa
Fault Module Name: clr.dll
Fault Module Version: 4.0.30319.18444
Fault Module Timestamp: 52717e84
Exception Code: c0000005
Exception Offset: 0019ff59
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: f808
Additional Information 2: f808516e6c707f824f162c986fe8ece3
Additional Information 3: faf6
Additional Information 4: faf65f5ba5b3e4e35225d03eee8a8df1
    edited March 2017
    This error indicates that a component of .NET 4.0 (clr.dll) is what actually crashed when recovering used memory (garbage collection).  I would recommend running Windows Update first and install all OS updates.
  • Jerry W2TXB
    edited February 2017
    I had done all the updates on 4/30/2014 (following a re-install of Windows 7), including the .NET 4 and 4.5.1, and the log shows they installed successfully at that time, as did everything else. The only other update was for the security bug in Internet Explorer 11.
    Just for the heck of it, I ran Windows update three times during the past hour; on the third run, it picked up a security update (KB2835361), but that was all. I installed that and rebooted the PC and the radio (with power disconnect/reconnect). So far, so good; I will keep an eye on it
