1.2.1 SmartSDR window freezes
Drax
In the new 1.2.1 version..
Sometimes when I leave SmartSDR running and my DAX feeds monitoring when I come back the SmartSDR window is frozen and is all white and unresponsive.
The audio from the radio and DAX feeds continue to work, but I can no longer control the radio until I **** SmartSDR and re-start it. On re-start it doesn't restart where I left off, but has some seemingly random set of panadapters open that I didn't open.
I have all of the power saving features in Windows 8 disabled including a disabled screen saver.
A bug in the new waterfall code? Maybe?
Your situation sounds similar to mine, but not identical. In my case, the waterfall and spectrum displays continue to run, but I can't click tune, nor can I hear any audio in the headphones when I tune to what's obviously an active signal in the waterfall display. The DAX feed continues to work, however. I need to **** SmartSDR and restart to get things back to normal,
Are you running DDUtil v3? I am, and I'm beginning to suspect that this has something to do with the issue I'm seeing.0 -
My audio and DAX continue to work. The but whole window is blank. I am not running DDUtil.0
- 694 The Flea Market
- 357 FLEX-8000 Signature Series
