After upgrade the radio starts "scanning" up in frequency.
W1IMD
W1IMD Member ✭✭
edited December 2016 in FLEX-6000 Signature Series
After upgrading to 1.2.1, I started SSDR and the slice immediately started moving up the band (didn't matter which band) and kept going beyond the band edge. The only way I could stop it was to lock the slice.
A quick email to the Help Desk got a fast reply from Dudley asking if I had a microphone plugged into the front jack, and sure enough I did. Removing the plug stopped the slice from moving.
Dudley suggested that some of the Heil Foster plugs can be inserted upside down causing this issue. I'm fairly certain that mine wasn't and I've plugged the mic back in a couple of times without issue, but if this happens to you, look here first. I'll continue looking at this.
Thanks Dudley!
