JT65 AND FLEX 3000
Mark Gottlieb
I have a FLEX 300 SDR 2.7 and use the WJST JT65 software, Windows 7, Dell Dual Core. Sometimes, not all the time, TX will cut off at approx. 24 seconds into cycle. I will have 0 watts going out. Rig will remain in TX mode until 48 second cycle is over and then will click back to RX as per normal. Sometimes, I will Halt TX and when I click TUN there is no problem with signal output from the radio. I will close the program and select again and problem goes away for a while only to return. I have checked sound card settings and it is at 48K 16 bit and my Windows Power Options are set to High Performance. I have no problem with the other digital modes(PSK31) or SSB TX. Any ideas??
- 322 Shack Infrastructure
- 227 Networking
