Can't Setup DDutil v3
Jerry Gardner
I have a Flex-6500 running SmartSDR 1.1.3.42. I wanted to try DDUtil, so I downloaded 3.0.6.00 from the K5FR website.
I installed DDUtil on my system and accepted all of the defaults. My system is a Core i5 system running Windows 7 x64 with 16GB of RAM, an SSD, and an nvidia 6600 graphics card.
When I run DDUtil and go into the Setup options, there are two options on the Features tab under Radio Select: Signature and Legacy. When I click on the Signature radio button, I get an unhandled exception dialog complaining about "Object reference not set to an instance of an object."
I've tried running DDUtil setup both with SmartSDR running and without it running.In both cases I get the exception when clicking on the "Signature" radio button.
Any idea how to fix this? What am I doing wrong?
I tried it again after SmartSDR had been running for a few minutes and it let me select "Signature" without throwing an exception. I don't know why it did it initially, but it seems to be fine now.0
Not sure but I do know DDUTIL once run creates a profile file and if it's not there or corrupted you get all kind of weird behavior
73 W9OY0 -
I tried running DDUtil for the first time while the 6500 was still initializing and that may be what caused it to throw the exception. When I ran it again a few minutes later it worked as expected.0
This question might be bettered addressed if posted to the DDUtil Yahoo group where Steve provides support.0
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
