Loss of Network Connection
Bob G   W1GLV
Bob G W1GLV Member ✭✭
Why does the radio loose LAN connectivity after being on for more than 24 hours. This does not happen on a regular basis. I've been trying to pin this down but so far it has alluded me.
  • Neal_K3NC
    Neal_K3NC Member ✭✭
    edited April 2014
    Bob,
    I do not see it, I wonder if there is some event on your PC that is causing this (like going to sleep/hibernate)?
    Try connecting to DXSummit or whatever dxcluster that has a web interface and leave it on, see if it breaks.
  • Reg
    Reg Member ✭✭
    edited March 2017
    Bob:
    In addition to Neal's suggestions, which are very good, check to see if there are any power saving options for your LAN adapter.  Some LAN adapters have a power setting options and some do not.  If yours does then change it to stay awake.
    Reg
  • Bob G   W1GLV
    I would like to thank Neal & Reg for turning a few lites on in this 72 year old brain. In any case the problem was a power saving feature of the network system. I have turned it off and we'll see what happens. I'm sure that's the culprit. If not I will let you know. Thanks again.
