CWX
Andrew O'Brien
Member ✭✭✭
CWX and PowerSDR crash when sending several macros in a row. See http://www.youtube.com/embed/ZUUKIJ2qi10?vq=hd1080 for an example, crash happens around 25 seconds in. PowerSDR has to be rebooted when this happens. It has happened on a Flex 1500 and Flex 3000 with different PC, different versions of PowerSDR, different versions of Windows . It happens when transmitting with zero drive, so not RF related. It is fine if I leave several seconds between each macro .
I have 1500 and have had a 3000. The same happened to me. You have to wait for one macro to finish before starting another. I ended up using macros in an external program.
roger0 -
I guess the question is "why" this happens and what might be done in the future to fix it. I don't think it is exactly a case of waiting until a macro is finished. You might be correct, but I think it has happened to me where one has finished but it crashes because I did not pause a certain amount of time between macros. Having to wait , and introduce pauses, renders CWX useless for all but the simplest of uses.
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
