Flat line Panadaptor on 40m
G4BIM
G4BIM Member
edited December 2017 in FLEX-6000 Signature Series
Flex 6700 Smart SDR 1.1.3. Running one slice only on say 160 or 80m, when you change band to 40m the RX signals disappear and the panadaptor shows a flat line at -127dB.
If you open another slice on 40m it all recovers and you can then close the new slice or the original one and  operation is normal again on 40m. I have had this issue for some time now and have done my best to illiminate the possibility of this being an issue related to items connected with the 6700 or its software. Any ideas ??
  • Robert -- N5IKD
    Robert -- N5IKD Member ✭✭
    edited March 2015
    Have you tried switching the RX antenna back and forth?
  • G4BIM
    G4BIM Member
    edited January 2015
    Hello Robert
    Yes when you switch from the default ANT1 thro ANT2, RXA RXB and XVTR, it does recover.
    Is this proceedure in the manual??? or is it a fault.
    Thanks for the input
    Peter G4BIM
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Hello Peter,
     By any chance do you have different preamp settings for the antennas you are switching? I.E. Main Ant1 as opposed to the RX1 antenna?   Persistence does not seem to always save the preamp settings when switching among various antenna ports yet.
    Regards,
    Larry  K1UO
  • G4BIM
    G4BIM Member
    edited January 2015
    Hello Larry
    My requirements are fairly simple, just Ant1 only with the normal random variation of pre amp settings as conditions dictate.
    This issue is no big deal, but I thought it should be reported.
    Perhaps it will correct itself in the next software release.
    Kind regards
    Peter G4BIM
