heil Proset ic + AD-1-Y
Steve - M3SXA
Steve - M3SXA Member
edited December 2017 in FLEX-6000 Signature Series
Got the above 2 items the headset was used with my old Icom 7600 and I just bought the AD-1-Y adapter for the flex 6500 but cannot get audio out of it, do I need to change the microphone insert for a non icom one or do I need a complete new headset? or is there a setting I have missed somewhere?
BIAS is off
+20db is on
Mic Gain up at 100
Getting the TX light ok....
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Hi Steve,
    If memory serves me correctly the Heil Ic was intended for use normally with Icom Radios and does require Bias to be on for the condenser element.  You should be ok after turning BIAS on for it....  I know I have seen others using that combo.
    regards,
    Larry  K1UO
  • Steve - M3SXA
    edited February 2015
    Hi Larry, sure it tried it with bias off and on and zilch.... just fired it all up again and with bias on it's working.... thanks for the advice...
